FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Trying to find wiring diagram for trim tilt system Volvo penta AQ271C(1990).Is it any connection from the starter to the powertrim pump thrue the 55amp fuse sitting on the starter?
Hi Found this fuse under the engine this summer, changed the starter a little later without knowing that the fuse should be on there and everything else works well. Do you mean that this fuse should be connected behind on the starter and further up to the trim tilt engine?I am not very good at electricity but appreciates that someone bothers to care. Thank you so much for good input.
Hi Thanks for the reply .I have to check if there are any loose wires I do not see. Have a 50 amp cut off fuse that sits next to the coil. I get to check closer tomorrow when I'm in the boat.
