Tilt/Trim unit fluid replace - '75 115hp Johnson
mlippinc
Hi,
Just replaced the seals on the tilt/trim pistons and need to know how to replace fluid. How much, proper bleeding, etc. I've heard two things - either fill from the top reservoir screw (on solenoid and bleed through bottom 3/8 fittings 5 or 6 times) or with the pistons in the up position, fill from the bottom (under pressure) and put the top screw in when the fluid comes out - similar to a lower unit I guess. Any ideas? Thanks in advance.
Maurie
jonesg
Re: Tilt/Trim unit fluid replace - '75 115hp Johnson
I think its easier to fill as you assemble, otherwise fill as you can and bleed it.
