Re: tilt &trim unit problem
ob, your right,when I took the motor out the little hex shaft fell into the oil out of sight.I removed the oil and saw something loose in the bottom. That put a smile on my face. Replaced shaft, aligned with motor ,put the oil back in and BINGO....its works....now I have to figure how to wire it up..It came with a 3 wire harness, up ,down,power, where's the ground or negative wire?? Bruce
