Tilt &Trim
mitchell6
I've got a 1973 135hp Johnson and it's running good, but the tilt motor sound's like it's running fine but is slow picking up the motor. I checked out everything and the only thing I could find that didn't look right was the passenger side tube (shock) don't really know what you call it looks dry when you raise the motor all the way up. Took it off and it's not holding any commpretion. What do you call this part? :confused: Need to know where I can replace it. Thanks ahead for the help
OBJ
Re: Tilt &Trim
Welcome to iboats mitchell6!<br /><br />The port side cylinder is the trim cylinder....starboard side (right) is the tilt cylinder.<br /><br />I need to ask, is the fluid level in the reservoir OK? If you need to check it, remember that you do this with the engine tilted all the way up. If you need to add fluid, fill the the reservoir to the bottom of the plug hole, losely put the plug in and cycle the engine all the way up and down 3 to 4 times and check the level again. The cycling bleeds the air out of the system. When the level stays at the bottom of the plug hole, it's good to go.
mitchell6
Re: Tilt &Trim
Yes it's was full of fluid before I took it off anyway's I've found a place close to the house that willl rebuild it for me sence I can't seem to find one, (seems they don't make any after market cylinder's for that year anyways.<br />Thanks for your reply
mitchell6
Re: Tilt &Trim
Ok got me a different cylinder, now 2 quick ??'s. Do I need to take the plug looking thing off the side and put fluid in it before I put it on? Or does it just fill itself up when your making the motor go up and down. You said earlier I needed to go up and down about 4 times is that by hand or with the tilt motor?<br />Thanks for your help
OBJ
Re: Tilt &Trim
No need to prefill the cylinder. It'll fill itself and vent back to the reservoir as you cycle the engine up and down. You will have to add fluid through this cycle to get the reservoir up to the correct level. <br /><br />And don't take that plug off the side of the cylinder....that's your trim sender to the gage. There's a little ball and spring under that cap. Lose them and no trim gage signal.
mitchell6
Re: Tilt &Trim
thanks OBJ didn't know what that plug was for didn't no if it was a quick fill plug or what. Thanks again for everybody's help.<br />Mitchell
