tilt trim
bruce yager
have a 90 v4 johnson tilt and trim will not work. How do I manually raise motor so I can transport to marine repair shop?
cougar1985
Re: tilt trim
there should be a release valve on the lower right side,if i remember correctly it is a flat blade srew driver type.look a couple of inches above the 5 or 6 tilt pin holes you will see it ,it is recessed.
tashasdaddy
Re: tilt trim
it is suppose to be torqued to 40, so it will be really hard to open. the tilt motor wires should have a bullet connector, near the tilt control box, disconnect and jump power to the wires, if the tilt works, the problem is either a solenoid, or switch.
