Tilt won't work
Triumph1
Put an older 88hp Johnson on a 98 Aquasport 16' and can't make the tilt motor work.
Crosbyman
tell us more… does it buzz, click ,wirl, stays silent, hesitates jams did it ever work on the other boat ?? ….. have you done any voltage checks anywhere, how are you with a volt meter ??
Triumph1
It works if i apply direct power up and down. The switch on the throttle just up, unless i swap wires. I hooked a new switch up to the wires at the throttle, still just up.
80s Johnson 88hp, 98 Aquasport
jimmbo
Where are you swapping the wires?
Triumph1
It has the typical blue/green wires, only 2 wires from trim motor. A holder with 2 relays attached to motor with green and blue wires coming out.
Triumph1
Out of the relay box on engine.
i tried to upload pictures, it doesn't want to work.
jimmbo
Have you checked for Continuity between the Trim Switch and the Relay box?
jimmbo
With the Trim Switch wires unhooked in the Relay Box, attach the Ohm meter to the Common and to the Down wire, Close the Down Switch, and watch the meter
Do you have a Wiring Diagram?
Triumph1
Just the one on the cover of the box, I'll pull one up on the internet and do the continuity check.
Tassie 1
ATM there is a number of youtube videos showing similiar problems,
Been there, doing that.
Triumph1
Thanks for everyone's help, tracked it back to the switch, anyone know who might have the correct switch? I am looking online and don't find one that looks the same. It's kind of contoured or should I just put one in the dash?
jimmbo
Have you tired a Dealer, they sometimes have the exact one in stock, or will be able to look it up and likely order one
However, before you go buying a switch, you did verify that the Wire is good?
