Time to reassemble
flashback
Short story is I would not be at all surprised if a chinesium drive requires adjustments after running for a couple hours.
Guess that why they call it a shake down cruise! In my case the shoe fit ok. It shifted really well at first, I ran it thru the gears several times in open water and it shifted fine, then coming back in I chunked it into neutral and then hit reverse for braking purposes and found I had no brakes. I felt like Forrest Gump watching his boat go thru the wharf. LOL..
I'll get it out this weekend a bit and see where things go. I'll say one thing, Sea Ray sure didn't skimp on the glass and resin. This boat is heavy, it rides like a 747. The Chris Craft I had was 15 years older and a foot shorter and much lighter.
flashback
Well I followed the SEI break-in schedule faithfully and have clocked up 10 hours of run time below 3000 rpm, and have run it up to full throttle a bit and I'm happy. The drive still wines but less than before or I got used to it, being only the second boat I ever had with an I/O I don't really have anything to compare to.
I let the boat set in the water for a week and didn't take on any water so that's a good thing.
Sorted out the corroded wire connections for the dash lights and everything electrical that I'm aware of is working. The tach drifted a bit at first but I picked up a tip in another thread saying to turn the setting screw on the back of tach a few times and that solved that. I can't remember who it was but Thanks! Have a couple of toggle switches that I have no idea what they are for but there is a decal on the dash referring to a halon fire extinguisher which I can't find so maybe they had something to do with that. who knows.
The shifting is good. It will shift into forward and reverse nicely and comes out of gear well in reverse but coming out of forward occasionally requires a slight tug on the control past the stop point. Since there is so many places in the system to make adjustments I could use some help as to what to adjust to get it to disengage a bit sooner.
The engine is running great, starts easy. no hesitation and is strong and quiet. I'm afraid to touch anything on it but I should pull a couple of spark plugs at least just to see how the mix is. It does love it's gas.
Anyway, I think I got lucky with this boat, Had originally thought to get it running and then sell but I'm getting quite fond of her...LOL
Thanks for all the help folks..
flashback
I would like the drive to drop out of forward a bit sooner when returning to neutral. It goes into forward well before the throttle advances but sometimes I need to press the trigger on the control and pull it a bit further when going to neutral. Would bending the interrupt roller a bit closer to the V block help, or maybe put the shift assist back on? I figure one of the many adjustable points on the shift system will probably fix it, but It's working well now and I don't want to fowl it up.
kenny nunez
If you watch the video that Achris has on adjusting the shift system that may be all you need .
flashback
I will, the video is good and watched it many times, maybe I missed something. I will run the adjustment again and probably learn..
When Chris does the control cable adjustment and went to the helm to shift it back to forward I see the remote move a bit and that confused me. How can that be?
Rick Stephens
The movement you see is also from the throttle cable, not just the shift cable which moves exactly 3 1/8" on his controls..
flashback
Yes I get that, but when he went back to the helm after measuring the travel in the remote cable he shifts back to forward to set the barrel on the remote, when he did that l saw the lower cable move. Maybe the drive popped out of gear at the same time. Just watch it and let me know what you see.
flashback
Oh am I so wrong, I watched it again and it's the throttle cable that I saw move a bit. Jeese I feel like a jerk!
flashback
That's what public forums are good for - making oneself smaller. I do it regular like.
LOL yep, I sure went down the rabbit hole on that one! I guess I should get my head out of the searay for a bit, grab a pole and go fishin!
