Re: Timing 180 degrees off!!
After much cussing, head scratching, wire swaping, battery re-charging, etc., etc ... I believe I may have found the problem.
Wires are not crossed, flywheel key is not sheared, crankshaft is not broken (thank goodness!!). Good compression, good spark, getting fuel.
Thought maybe the timing base was somehow shorting out the power pack so ordered new ones. And surprise, surprise ... the new timing base didn't match the old one.
After even more head scratching & cussing I've discovered that at some point in time someone has bolted an '83 powerhead up to this '85!!!!
