Timing a 4.3L Vortec engine. No timing marker on TC
tazzerblue5
I had this engine rebuilt, and there is no timing marker on the new TC cover. The crank dampener has marks. How do I dial in TDC?
Did you do the assembly work, or did the shop?
Which timing cover is on the motor, the plastic one, or the billet amuminim?
because, unless someone ground off the timing indicator, it should be there on the cover, and the balancer will have a groove machined in it
Use either an advancing timing light or timing tape
measure balancer and get timing tape if you dont have an advance timing light
