Timing Advance?
ckswanecamp
I don't know how to time this motor properly, but I understand this much:
"Timing advance" refers to the number of degrees before top dead center (BTDC) that the spark will ignite the air-fuel mixture in the combustion chamber during the compression stroke. Retarded timing can be defined as; changing the timing so that fuel ignition happens later than the manufacturer's specified time. For example, if the timing specified by the manufacturer was set at 12 degrees BTDC initially and adjusted to 11 degrees BTDC, it would be referred to as retarded. In a classic ignition system with breaker points, the basic timing can be set statically using a test light or dynamically using the timing marks and a timing light. really, whats that?
My Motor:
http://forums.iboats.com/showthread.php?t=457972
I have researched this process long enough to understand that its complicated. Thats about all I really learned this far. Can the timing be as simple as setting the points gap to .020?
I don't understand where to adjust the postion of the piston, and in relation to what? theres no witness marks or such. Theres a key that is on the top of the shaft that flywheel joins to, and the high point where the points break contact fits in the same key as the flywheel, so everything seems rigid and i don't understand that process and where the allowance for adjustment is.
In addition, there is a curved plate that the parts list refers to as a "cam" which rides against throttle/spring on the butterfly. It is connected to throttle linkage from the tiller. This plate has minimal play for adjustment. So i am sure this needs to be brought into play.
I am gonna put this motor back together on sunday (13FEB2011) with the help of a friend who is a small eng mechanic. I got a complete gasket kit and an oil seal to replace. He's checked out the motor and tryed tuning it while it was running last week, but we're both unsure on how to get this thing to idle properly. she runs great at full throttle though. we figured it the timing advance. whats your take?
thanks for reading.
F_R
Honorary Supreme Mariner
Re: Timing Advance?
You would have gotten a quicker answer if you had told us that is a Clinton.
Anyhoo, full advance is USUALLY set so the points break at a certain distance of the piston from TDC. Sorry. I don't know the spec. A guestimate would be 3/16" BTDC.
But that has nothing in the world to do with idle speeds. At idle speed, the carburetor butterfly should be completely closed and the speed is then accomplished by spark retard. The amount of spark retard is controlled by the sliding throttle/speed control on the front of the motor. Move it toward "slow" and it retards the spark. Move it toward "fast" and it advances the spark and opens the carburetor butterfly....till it is limited at WOT.
The point at which the carb just begins to open is referred to as "sync" and is fairly critical for mid-range performance.
M
mrcrabs
Guest
Re: Timing Advance?
Marshall public library has a free clinton manual,​
SPEED CONTROL LINKAGE.
The speed
control lever rotates the magneto stator
plate to advance or retard the timing. The
throttle valve is synchronized with the plate
to open throttle as timing is advanced. The
high-speed position is fixed. Slow idle
throttle setting can be adjusted as follows:
Move speed control lever (1?Fig. CL3)
against slow speed end of stop as shown.
Loosen the two cap screws retaining speed
control cam (3) to stator plate and move
plate toward or away from throttle arm (2).
Do not attempt to adjust slow speed by
tuming the slow speed MIXTURE needle.
Check to make sure throttle valve is fully
open when speed control lever is moved to
"FAST" position.
Go to: http://search.ebscohost.com/
Log in with:
P.W. : public
-----Go under the Small Engine Repair Reference Center then marine....you will find it.
ckswanecamp
Re: Timing Advance?
Thanks for the help fellas.
I guess at this point, I will assemble the motor, and just tinker with the cam that rides against the throttle arm to sync the carb/ignition.
I understand:
-that full throttle is fixed, and the cam should engage the throttle to 100%.
-that at idle speed the butterfly must be closed.
Thats a simple plan. Hopefully nothing more is required.
M
mrcrabs
Guest
Re: Timing Advance?
Generaly when you disassemble/re-assemble a Tecumseh or Clinton outboard nothing changes with the sync unless,
  1. You changed it (cam).
  2. misalignmened the stator plate.
  3. used a different part, ie carb, reed box, stator plate.
  4. gasket thickness is not the original specification.
  5. something got bent or unevenly torqued.
I have done them all! ;)
ckswanecamp
Re: Timing Advance?
the only components that will be changed will be the oil seal (lower) on the block; and a complete gasket kit.
all other parts for the powerblock will remain the same. i just removed everything and cleaned it up real nice (inside and out) and lower unit has been good to go.
i'm glad i tore the motor apart because that lower seal was all jacked up, leaking fuel and oil directly into the exhaust leg. my test barrell was polluted!
i am hopeful once the motor is assembled it will fire right up, easy to tune and i can be done with it.
hey mr crab's- i got a 1970 Eska Golden Jet 1715B http://forums.iboats.com/showthread.php?t=458159
this outboard is missing a cowl and/or a shrowd. some kinda cover, not sure...
i cannot locate a part# or even a picture of what i am even hunting for. can u point me in the right direction? thanks....
