Timing causing misfire?
Masonmoore
Ive been working on the carbs on a mariner (cleaned and rebuilt them) and it still runs the same. Idles rough, shakes, and not much power WOT. I havent had the engine timing adjusted. Could this be the cause of the problem? Thanks- mason
sutor623
Sure, timing can make or break it. Can even keep it from starting at all. If the WOT stop isnt set right, you could blow the whole show!! What motor we talking about here?
Do you know the history of the motor? It'd be odd if the timing were that far off unless some idiot and his screwdriver were poking around without a timing light.
Masonmoore
Its a 1982 80 hp mariner. As far as history goes, all I know is since ive got it. I started it up on muffs when i got it and it ran, but then it sat around for around a year.
Masonmoore
Well i didnt get it on the water last year, but when it ran, it idled about the same as far as I remember
GA_Boater
Yes ^^^^^ and check for spark on all cylinders. Is the fuel fresh?
Masonmoore
Yes ive run fresh gas everytime it was run and put a new fuel filter on about a month ago
