Re: timing chainsaw
If the chainsaw has a single coil/plugwire assembly & no points it is timed by the amount of air gap. When I replaced the coil on my Lawn Boy lawn mower I checked with the local Lawn Boy shop to determine the proper air gap. Seth (the lawn mower guru) said he didn't remember the Lawn Boy spec, he just allways used a business card. Loosen the screws holding coil, place the business card between the coil and the flywheel magnet, and let the flywheel magnet pull the coil tightly against the business card. Then tighten the screws, remove the business card, put everything back together, and mow grass. The chain saw is probably the same way except the last instruction would read "cut wood". <br />Bill......
