timing cover replacement
bsmonster
I read in a older fourm that GM part # 3992251 would work for my 1989 mercruiser 3.0 L timing cover replacement. anyhelp would be nice. my engine serial number is 0C542094. I looked up part and was only $75.00 and that beats the $220.00 for a mercruiser part
Bt Doctur
Re: timing cover replacement
the GM part should work just fine
achris
More fish than mountain goat
A-ha.. I can top that... My timing cover is a $39 GM part, for which Merc Australia want ........ $350!!! :eek:
bsmonster
Thanks for replys.:joyous: we were discussing weather to get a orignai part or not and desided to see what you all thought. we are going with the GM part #3992251 I'll let you know how it went. I still feel like a Guinea pig. :happy:
fishrdan
Buy it from GM and you'll be getting an original part, without Mercruiser's mark-up.
If you're old cover rusted through, I'd hit the new cover with a couple coats of Rustoleum.
Ayuh,.... As well as the oil pan, while the motor is out....
bsmonster
Thank you feeling better now about trying this route. I will paint all exposed bare metal and replace any rusted bolts. Its sure is fun working on our boat. I swore i would never work on cars trucks or toys again. well guess I was wrong. (15yrs later) lol I"m having fun. this forum is a great resource. PS this weekend is the opening day of boating season. and we are doing yard work... Not my idea of fun
smassey22180
Any updates from the Guinea pig? Where did you end up finding the GM part? I just did a quick river test and have a pretty good oil leak up front at cruising speed.
bsmonster
no luck on part do to no ETA ugh I tried three different part suppliers all sent me email saying it's not available.. so had to go the high $$$ way I ended up paying $188.00 for new cover :grumpy:
1034
I found this timing cover for $14.00 at Advanced Auto Parts with the oil seal and the cover gasket. It's made in China but it worked great for me. It doesn't have the timing indicator on the side. It also doesn't have the threaded holes on each side were it mounts to the oil pan, but all I did was drill the 2 holes out and used 2 -- 1/4x20 lock nuts. Part # 6092185998 China 11338.
Don S
I don't think he was looking for the cheapest junk on the market, he was looking for something as good as OEM, and since OEM is GM (Merc doesn't make timing covers, they buy them from GM) the GM # is what he wanted.
mwf35
Do you know the advanced auto number? I searched advanced and googled the numbers that you put up and got no hits. Thanks
