timing for merc 50 hp 4 stroke
Jambone
I want to check if the timing is set right on my 2002 50 hp 4 stroke Merc. I suspect the timing belt may be off by a notch or the system is not set correctly. Do I need a timing light or can I check things without?
Many thanks
carholme
Re: timing for merc 50 hp 4 stroke
What is your engine s/n? Do you have the service manual? If not, send me a PM with your email address and I will send you a copy.
From the manual:
NOTE: The 50/60 four stroke ECM unit electronically controls the ignition timing, therefore
making the ignition timing non adjustable. When initially running the outboard, use a timing
light to verify that the ignition timing falls within the timing windows. If the ignition timing does
not stay within the timing windows, replace the ignition ECM unit and retest.
Gerry
Jambone
Hi Gerry, I don't have the service manual. The serial # on the motor is 0G254348. I was told it was a 2002 but I can't seem to verify that. It is a 4 carburetor version. I would really appreciate a copy of the manual!
My e-mail is jamescald@live.com
Thanks
Jim
From the manual:
Gerry
