Timing info 1996 Johnson 130hp
goatbreath
Would appreciate timing degrees for j130tleda WOT and idle. Bought online manual but can't find them. Sorry manual. Thanks
Honorary Supreme Mariner
Need to ask.----What is your motor doing / not doing ?-----Timing on these motors does not go out of adjustment.-----If there is an issue what trouble shooting has been done ?
goatbreath
It won't idle properly. Spits misses. Over half throttle good. It has been to 2 supposidly good shops. They messed it up. Adjustment tip was off idle lever. lever is adjusted all the way out and I would like to try Joe Reeves method of WOT timing check. Can't find WOT timing degree. Thanks
goatbreath
I have cleaned all carbs. New plugs. Adjusted idle screws from 4.5 turns out to 7 turns out and everything in between. Ran with auxillery fuel supply. Still not right.
Post compression numbers.----Running with VRO in service or 50:1 mix ?
goatbreath
All cyl 110 to 120 psi. VRO operates well. Old engine but very low hours and well taken care of. We don't have many boat engine mechanics here. I have some 2 stroke motor bike experience and a little boat motor experience.
goatbreath
Thanks for taking the time to reply.
goatbreath
Thanks for timing info. Just want to see if “mechanics” messed with timing. When I advanced timing lever (counter clock) idle got better but I ran out of threads. Also do you know normal turns out for carb idle air adjust screws?
