barthel
Thread starter- Joined
- Mar 20, 2012
- 94
Morning All,
I was trying to set and/or verify the initial timing on my boat this morning and ran into an issue that I need help with.
First, the particulars: 2000 Volvo Penta 4.3GLPEFS engine, Delco EST distributor and an SX-M outdrive.
I followed the instructions provided by Don, warm engine up, check idle, shut engine down, plug in the distributor shunt but do NOT connect it to 12V until the engine is running.
Well, the first thing I noticed is that the plug where the shunt should go had nothing plugged into it, it was just a rubber cap covering the connector hole. So, I plugged the shunt in, started the engine and once running connected the shunt to 12V+. As soon as I did that, the motor died. I wasn't sure I did it right, so I followed the same steps 2 more times, and both times the engine died when i connected the shunt to 12VDC.
What am I doing wrong or missing?
Thanks in advance.
P.S.
I did check my connections to make sure I wasn't grounding out anywhere, and I'm not (or at least it would appear so)
Thanks in advance.
P.S.
