Timing mark again
TMALEGA
Hello all i was about to post this question and noticed frank answered a similar one from a 125 84 model. I have the 85 hp 1985 and only have the 2 marks on my flywheel also. Is it the same setup? Far right one is the tdc and the one to the far left is 30 degree?? Also i cant figure out how to adjust it. I see the nut up way under the flywheel but is that the right one? Is there a trick to getting up to it with the motor turning?
Frank Acampora
Re: Timing mark again
The flywheels are exactly the same, so timing marks are also the same.
Since the locknut and screw slot are under the flywheel, adjustments to timing are done with the engine stopped.
Because you don't want to paint the flywheel red and join the nine finger club, you stop the engine before making adjustments. Therefore adjustments must done multiple times and in small increments to get the advance correct.
my1stboat1
frank how do you make the adjustment i cant even get a wrench under the flywheel to loosen the jam nut, my time is at 26 degrees full advance static timed.... Id like to get it to 28 or 30 i assume thats were its suppose to be
