Thanks to anyone with answers to these questions....
I have a 1977 Evinrude 55hp and I believe the pick up timing is wrong. I have both the factory manual and a Seloc, and to me, they are both unclear concerning the linc/sync. I understand the cam meeting the roller forcing the throttle to open at the right time. What I don't know is...should this happen as you go into gear, or after? In other words, as it sits now, the line on the cam is in the center of the roller, while it is in neutral. From everything I understand, the timing should advance before the throttle opens. To me it looks as the nylon block on the timing advance rod has been moved. The warm up lever also advances the spark as well as open the carb butterflys? Is this correct, or should the warm up lever only advance the spark?
I really appreciate any help.
