PcolaBeach
Thread starter- Joined
- May 26, 2019
- 26
Good morning all,
Subject engine recently had block replaced for a variety of reasons and I'm concerned the distributor installation might be off. The attached curve is of engine rpm's, check engine light, knock retard and spark advance. As the engine is first started and running, the spark advance is roughly +5 to 8 degrees ATDC. Upon the initial run up at around 3000 rpm the knock sensor picks up and retards the spark advance by -5 degrees (coincidental with the check engine light) from 32 to 27 degrees. Upon reducing the throttle to idle the timing is erratic between 0 and -5 degrees BTDC. Engine top RPM's are also limited to 4000 while 5000 is expected.
While I understand the timing is set by the ECM, I'm interested in feedback from others as to whether the values above are what you would expect? For some reason I'm unable to attach photos or files at this time.
Thank you!
The engine information:
Volvo Penta 5.7 GXi-C Raw Water Cooled
Serial Number 4012062213
Production Number 3869137
MEFI Assembly Number 57IAFM/02HT01 3861773
Boat - 2002 Cobalt 240
Thank you!
