Sureshot
Thread starter- Joined
- Sep 28, 2011
- 97
Hey all, I'm wrapping up a rebuild of my 2000 50 HP 2-Stroke johnson. I've completed the link-and-sync per the manual but wanted to give Joe Reeves timing method a go since I don't have proper test wheels and tanks, etc. I have a few questions about the procedure.
1) What's the preferred way to ground out the #2 plug? Push it up against a head bolt or run a wire via alligator clips from the boot to the block?
2) 1st time using a timing light. While I'm cranking the engine, do I simply point the light at this timing mark next to my flywheel (see picture below, tried to circle the mark in red)? And the strobe light highlights the number the timing is currently set to?
Thanks as always.
Thanks as always.
