Merc 88' 200 V6
I don't have the timing pointer on the flywheel anymore (got lost) but the flywheel still has the degree tick marks. So I was hoping I could do the following:
-get a dial gauge with a magnetic base and find TDC on cylinder #1.
- Then make a mark on the block right under the 0 degree tick on the flywheel. This should tell me when the #1 cylinder is at top dead center.
-Then align my timing light with the mark on the block and use this as my guide for setting the timing.
-Then just follow my merc manual for normal lync&sync.
The only downfall to the method I can forsee is that I am not using the .462 timing tick method that merc recommends (anybody who has a merc has read this in the manual).
What do you guru's think???
