Tin addiction 18' Starcraft Chieftain
jbcurt00
Re: Tin addiction 18' Starcraft Chieftain
How thick is the transom aluminum skin?
Should total 2-2.25" total thru the keyhole for a Merc I/O....
Watermann
The set up I'm thinking could have been a 1-5/8" transom and a 3/8" horse collar = 2".
Edit: Now I'm leaning towards thinking the wood is coming apart and swelled up, took another measurement in the keyhole where it was not as bad and it was closer to being 1-1/2".
jbcurt00
Yep, you got it.... Just checking because I couldn't see evidence of the horse collar in the transom pix... Maybe slightly swollen from water, once wet, a good bit of ply stays swollen, it'll never be kiln dry again so unlikely to shrink back to it's typical nominal size.....
How are you laminating the plywood pieces?
3X 1/2" sheets w/ a layer of glass & epoxy in between 1 joint (or maybe both) after multiple layers of epoxy should be 1 5/8" + a fuzz and be good.
The 1/2" MDO I bought didn't seem to be nominally as short as typical 1/2" plywood's 15/32"
But 3 layers of 15/32" = 45/32", that's 1 13/32" right, so you're 19/32" short of 2", which is what 5/8" ply is now (19/32") Might need glass & epoxy between both layers it the marine ply is 15/32"..
3/4" & 1/2" is 'really' only 23/32 & 13/32, so that's 36/32 = 1 4/32 = 1 1/8"
My best guess: 3/4" & 3/4" = 23/32 + 23/32 = 46/32 = 1 14/32 (not quite 1 1/2") add your aluminum transom skin & the 3/8" horse collar & you should still be GOOD!
BTW: that all allows for a tight glue joint between sheets that is negligible... My Duracraft transom glue joint is probably 1/64" MAX....
Watermann
Thanks for the info! Looks like I will be using the 3/4" marine ply x 2 laminated with the Titebond poly. Hope I don't get sticker shocked on the marine ply this year, I hear lumber prices are up here. Last year 3/4" was $70 a sheet.
jbcurt00
Is an 8oz bottle enough for an I/O transom? My Duracraft transom took nearly a whole 8oz bottle w/ just about the right amount of squeeze out, you might need more......
dozerII
I used two 8 oz bottles on the transom for the 201, so you will be somewhere between one and two bottles.
Watermann
No way 1 bottle would do it. I used 1 and a 3rd bottles on my SN transom and this one for the Chief is a monster, I will most likely have 3 on hand just in case.
pckeen
Are we still talking beer here?
jvanhees
Uh yeah a local brewery sells me their beer by the can. The frosty mugs are above next to the J?germeister.
Looks really good Water!
oh and the Chief too--stripping that hull...Im glad that is over and I didn't even help!
Watermann
Not done stripping yet though, I have a pile of tin in the garage that is giving me the urge to go out and tear into.
Started ordering some of the necessities this week, like gluvit and marine tex to have it on hand when the time comes. Shop, abandon cart and wait for the the emails to come get your cart with free shipping and up to 10% off coupon codes! Yeah man, I love being ahead of the game and getting some sorta bottom feeder prices on stuff. Also got a air riveter from HF coming and 10% off as well, thanks to a code roscoe gave me.
The old nasty and stinky transom is inside the garage too staring at me every dang time I walk in. Going to need some ply and glue here real soon to knock that chore out.
jbcurt00
hmmm
abandon cart
interesting
didnt have a 20-25%coupon @HF?
jvanhees
abandoning cart on which site? great idea
Watermann
Yeah, sign up with the online business, login and go shopping. Add what what you want to the cart and then abandon it by closing the page. A day or 2 later they start sending you emails wanting you to make the purchase. Some offer 5% others 10% and they will add free shipping to sweeten the pot. It's tough to beat Wholesale Marine's prices and they have a 10% off code right now and free shipping on orders over 50 bucks. The code is only good until tomorrow 11/27 SITE10.
Yeah JB your right it was a 25% off code at HF on the riveter.
dozerII
That abandon the cart idea works real good, some sites will have the email out to you within about 12 hours. I thought everyone knew about it. Good on ya for letting everyone know Water.
Watermann
Cold in the teens and blustery outside so the only thing left to do is start in on the tedious work of cleaning up the tin I have stored in the garage for winter busy work. I planned on getting after the cabin but the cuddy's compartment bulkheads and supports were on top of it so I got started there. This is what I'm looking at with a nice rusty high water mark.
y4m_4Oa516FON4xJIgFe-1Yjis-RafgQ016xbYbwcYfinBWmMBLyV2V0egCFWWskbUY7arCXoo0WHm7yRcadX80enjbHGxiCUkV_pb3A9R10hG4LElwARNF2A_Sg-SSviOHFFUSp_rb_5EG0hjP1gbqA1pBBEjbR2MWSZgPwkY0AHFzt6FecnytFOwA-rcmySdiF6M_pDTFKPM7aGUM2Bhokw
I disassembled all the smaller pieces and got to work on them first. I also patched up some cracked supports and angles in the bulkheads. The supports are a piece of channel that starcraft cut the sides off of leaving an extremely weak tab joint that cracked on 3 of the 4 ends. All 4 are getting repaired though. I drilled out the end of the crack and then cut pieces of scrap aluminum to size, back buttered with 5200 then riveted into place to beef up the flimsy tab.
y4mFiFkblit8WgEr47LEBfw9wXH64c5OKB35mBxqbvjLG96hHd5TbPGF42IR91FcZQjwZ7GnuTgNS0eSfbBlY1pxZfFPclBK_RZPRMlX4jFhJ5doTWWDSBelFOnBt588P3iM-V5LpTkfKmgE0VSsmkuRFAeh-11CEADejX-H13l5bpBE_GdBVQgCe4I48QOyYEnwQaIKZzGVNzEeg1FeSB7hQ
The repaired cracked tab.
y4mue6V0Z5tQ389d1JL-JzyctbUSw2lmUIdIQOjgIKk43vjwl9a1FUodrluEvnhuRYF54ZnSUUARLaD5fPHEZj_tze8MI8CMIMKyws7y8_dutNirzO8plkLf8wwdbKB5WxH5WG8AlEwHu3hYt8iooI4skGRiUl0Y7vBaVcVACOIr0VC9tKKabkkxEtZSNNumfEOKQtYVUKqR0cBfP7XyXdyIQ
I made similar repairs with angle aluminum on a bulkhead with a 90 degree bend that had a crack.
I ended up with the day off inside the nice warm garage and a bit of forward work on the Chief. The smaller pieces got sanded, wire wheeled, cleaned up and primed with Rusto SE.
y4mjvexiv-wlZsX-h3ztFmETwoDbsMP9vkHds_lzIDhJ3hKsN7YAWcyJaGpv85n4AuxTlf1YWEoC5e-V180yqfif_xG6Klb3KdA1NeCtDXPFj8BV-PGf_x-UmCWKkcXxfyais2oVw2D1r9Xq-j3Ua7gOdRRK-PJ3cZwzDYp2hmDW4WkkA0LRRwUSPHDY9AVhyyB0He8SwCAirdaJIPNxh2Usw
I almost forgot how bad corrosion smells when it becomes airborne, like moldy bluecheese stuffed inside an old gym sock. :D
Not too exciting work but hey like they say, it's progress!
jbcurt00
looks good WM, progress is progress. Nice coat of SE on the parts you sprayed............
crankbait cowboy
looking good h20, tuff to get stuff done in winter weather. 20 below farenhiet before wind making it feel like 35 below here in northern mn, and a foot of new snow.
jasoutside
Yah man, agreed. The way Starcraft put together those alum support pieces was pretty wimpy. You worked a great solution there buddy:thumb:
I'm actually kinda fond of that smell. If somebody bottled that up in an aftershave, I'd buy it:becky:
