tiny tach setup?
ncfish
two stroke fires once per revolution right? i did a search on here on the tiny tach and read that you set it on 2 sparks per revolution:confused: if the two stroke fires once per revolution, i'm thinking i would set it to 360 degrees which = 1 spark per revolution. is this correct?
Commando C2
Re: tiny tach setup?
ncfish, have you sorted the tiny tach settings? i have a 2 stroke 2 cylinder outboard and am wondering which setting it needs
one spark per revolution is a 2 stroke but i have 2 cylinders so thats 2 sparks per revolution? um....?
matth121
what was it's default? Mine worked right out of the bag, lol. same as you guys, 2 stroke 2 cyl, but ya your right, each cyl fires once per revolution, your only wiring it to one plug wire so thats all you need to worry about. are you getting weird numbers from it?
