Re: tips for adding a new center toon to a ponton
Took the boat back out of the water at the ramp today and dropped the motor one hole as well as putting the 13 1/4 x 13 four bladed prop back on and then put the boat back in as a storm was approaching. When I got out of the no wake zone I gunned it in smooth water and the boat accelerated to 30 mph non gps and hit 5500 rpm and was probably still gaining some when I had to back off to no wake speed again. Distance was probably no more than 1/2 mile if that. My speedo is fairly close to gps speed and if anything it, usually reads a mile lower, so needless to say I am pleased with the results. I still plan on adding the rest of the underskinning, but may wait a month or at least add up all the bills I have fixing up the boat over the last month. I believe that I may need to reprop after underskinning, but will wait to see. Right now I am waiting for the storm to pass and for time off to test it out with its current set up. It is hard to believe that one hole can make such a drastic difference. It is of course the last hole I tried, but just shows again shows that proper set can make the difference from a marginal boat and a good one.
