gm280
Thread starter- Joined
- Jun 26, 2011
- 14,605
Okay I asked about making such a thread for everyone to contribute to, to offer ideas that could help others doing boating or other shop projects. If the "MODS" think this is okay, then here it is, if not well that's okay too.
First, I am reasonably sure everyone has angle grinders and probably die grinders. I mean most folks that are reburnishing fiberglass most certainly does. Well seems cut-off angle grinder disc only last so long. Then they get discarded. BUT, there is still a lot of cut-off life in those discarded disc! But since it is too small in diameter to do the job on the angle grinder, off it comes and a new one installed. Well don't throw those too small cutting disc away. You can use them on your die grinder to do lots more cutting. Here are a few pictures to tell the story. You can see the difference in sizes between the two grinders.
Obviously the center holes are very different. But you can make a simple adapter to use the angle grinder discs for the die grinder by taking an aluminum washer or whatever you have available, and cutting it down to size.
As long as the center hole is ~1/4" and the washer you select to cut down is wider then the center hole for the old angle grinder disc, then the old used angle grinder discs will work. So you get plenty of cut-off abilities to use.
Next, And if you do have a die grinder and use the 2" Roloc 3M type sanding disc, you also know that once the disc gets used up on the edges, it doesn't work very well anymore. Well cut those disc off some and you have new edges to use again.
I usually use my bench grinder from the back side to trim them down. More use from them as well.
I am pretty sure most everyone mixes both paint and epoxies or polyester resins. And the catalyst has to be measured to make the paint cure and epoxies and polyester get hard. Well don't try to use the typical bathroom mouthwash type cups. They WILL dissolve and quickly. However, if you have and typical liguid medicine (Nyquil, Dayquil, Tylenol liquid etc.) type cups, they work perfect. And some are marked so you can use the appropriate amounts of catalyst.
And that brings me to another household item you can reuse. If you do mix epoxies and/or paint and polyester resins, reuse those plastic type containers (coffee creamers and coffee and such) to mix the ingrediencies in. I even marked the amounts on the side of the containers so I know how much I am mixing. And if you use those 4" rollers, they fit without issues.
And lastly, for now, When you us those wire brushes and they get all splayed out of usefulness, don't throw them away. Take them to your bench grinder and use the wire wheel on the grinder to straighten the splayed wire brushes back into shape. You will be amazed how well it straightens out those wire brushes. Just push the wire brush against the spinning wire wheel on the bench grinder with the wires facing downward and it straightens them like magic. Lots more usage from those wire brushes...
That's all for now... Hope you like this!
