Tire Load (Another One)
wolfe47374
So, After running my (1 year old to me) 76' Starcraft for a year with no issues, I decided to replace the trailer tires before we get out on the road again this year. Apparently 7.0x13 Bias can get a stunned silenced or quite a chuckle out of every tire place I could find.
My question is this on the load rating. The wheel/tire combo I am looking to buy has a rating of 1100# per tire/wheel (B Rating)
1. Trailer is a Shoreline V18-20 = 2000# load capacity - 545 total Weight
2. Boat is 965 Dry. 18 Gal fuel tank.
3. Misc gear, cooler etc.
I can't seem to find any reason to go from the B-Rating 1100 lbs per tire (2200# for the total load) to the C-Rating 1360 lbs per tire. When the price difference is over $150. (Not alot, I know, but every bit is counting nowadays)
I figure the tires cover the trailer load capacity anyways, am I cutting it too close?
any thoughts?
Silvertip
Re: Tire Load (Another One)
Where on earth are you buying 13 inch load range C tires that have a $150 premium. For gosh sakes do some checking. You can buy tires and rims for less than that.
Complete load range C with wheels.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200330250_200330250
Tires only (load range B - 1100#):
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200330358_200330358
Tires only (Load range C)
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200330374_200330374
wolfe47374
Where on earth are you buying 13 inch load range C tires that have a $150 premium. For gosh sakes do some checking. You can buy tires and rims for less than that. QUOTE]
Yes, the $150 was the difference for replacing 2 wheels and the spare (3 Wheels and Tires) Wheel- Tire Combo.
Real question is if I am ok with the load rating.
Thanks for the response.
Rancherlee
You only need the B tires if your total load is under 2200#. There is a safety factor built into the tires rating. If your Trailer + boat/motor + boating gear - tongue weight is under 2200# your good to go.
wolfe47374
thanks. Thats what I thought, but never hurts to double check.
