Andyfender
Thread starter- Joined
- Oct 17, 2009
- 136
The tires on my trailer say's Max load 60 psi. My boat is not that heavy. What is a good psi? 50?
For TRAILER tires, run the rated pressure.
The tires on my car have a max rating on the sidewalls. The sticker on the driver's door indicates a recommended pressure that is lower than the tire sidewall. I run the pressure that the auto manufacturer recommended.
On the other hand, the sticker on my boat trailer does not mention recommended pressure. When I e-mailed the trailer manufacturer they had a wishy washy answer.
This is a good question, but there is no good answer.
Carlisle Tire & Wheel only recommends and only warrants tires maintained @ the max air pressure while in service.
Maximum load range is attained only when the tire is at its maximum air pressure. There is no advantage to taking air out of the tire. With maximum pressure, the tire will perform and wear better, and you will get better gas mileage. Reduce the psi, and you compromise the functionality of the tire. This is the position that we take on this.
