davemoore
Thread starter- Joined
- Jul 7, 2009
- 96
We've had our used boat for a little over a year now, and are still finding jury-rigged garbage on it every time we touch it... but I think today's find tops the charts.
I recently bought a new prop right here on iBoats - a 14.5 x 17 Solas 4 Blade Alum with Rubex hub. When i went to put it on my Mercruiser today (replacing a 14.5 x 19 - 3 blade), I made a very disturbing discovery - the old prop (which is trashed) has been running without a hub! The only thing holding the back end of it (nearest the drive) was the thrust washer, which I couldn't get off no matter how hard I tried. The front (nut side) had a thing that was keyed in 4 places and mated to the shaft spline. It appears as though the new prop works fine though with the existing thrust washer - I checked the one that came with the prop compared to the stuck existing one using calipers and they're identical in size. But the nut that came with the new prop was the wrong thread for my shaft, so I had to reuse the old nut.
However, when I fired it up and ran it a bit just to see how it spins, I noticed a bit of a wobble... at first I thought I had a bent shaft, but upon closer observation I discovered that it's the prop itself that's wobbling - not the shaft.
Should I send it back? Is it a typical characteristic of the rubber hub? Not sure what to do. We're going out tomorrow, so I'll see how it runs...
Any thoughts?
Any thoughts?
