burnt clutch
- Joined
- Jul 3, 2012
- 40
I am stumped on this thing. I worked on it last year cleaning the carb and replacing the coils and I actually had it running for 10 minutes about a year ago. Shortly after it ran it wouldn?t run for more than a second or 2 at a time. I shelved it since it was September and I haven?t looked at it again until this month. Since my initial compression numbers were low I sprayed some WD-40 and into the Cylinders and later I poured a mix ATF of Sea foam into the cylinders hoping to loosen up the piston rings and break up any carbon that might be in the engine. Before I ran it I pulled the spark plugs and flipped the engine over to drain out any excess fluids. I tried to start it yesterday and it still won?t run for more than a couple of seconds. I got curious and removed the exhaust/Intake cover looking for reed valves but I couldn?t find anything that I think would interfere with it getting gas. I also took the carb apart and ran pipe cleaners through all of the orifices but couldn?t find anything clogged or that looked out of place. Is there anything else I should check before giving up on it? The carb has a new plastic float and new primer washers from Mr. Lautner. I guess getting a book on this thing should also be on my list ? would the Johnson Outboard Owner's Manual 302768 be a good choice as a service manual or should I get a different book? Sorry for the long winded intro and thanks in advance for your help!
-Karl
-Karl
