tn28 flywheel removal, what am i doing wrong
greenygreen
i cant seem to get the flywheel off. using harmonic balancer with soft hammer tapping while lifting up. How mean do ya have to get with these things?
Joe Reeves
Re: tn28 flywheel removal, what am i doing wrong
Having a good deal of pressure applied to the puller's center shaft, and prying upwards on the flywheel so as to eliminate any play..... BELT the top of that center shaft hard with a good size hammer... NOT a gentle tap!
Bosunsmate
Make sure those ht bolts are in the proper depth.
I do as suggested above.
Sometimes i torque them a bit more then leave it over night, often you will hear a loud pop from the workshop during the night as it comes free
a70eliminator
That all looks good, you have to put a great deal of pressure on your bolts, almost to the point of pulling the threads, then WHACK it good with a dead blow hammer, not ***** hit, it will POP.
The amount of torque needed you won't be able to apply by holding that strap, you need a prybar between the center bolt and one of other 3 or a huge cresent on the one square of the puller, then you can pull some torque.
greenygreen
shazamm . i thought somethin broke and took the puller off and she lifted right off. alot more pressure on it than i thought. So now i have an ohm meter so i have to find point of failure. no spark at top cylinder. now im really lost!
Bosunsmate
Thats a good thing to happen unexpectedly.
Ive bent ht bolts undoing flywheels and they a still stuck.
Has that model two coils?
If so switch the wires over and see if the problem changes cylinder.
Also a bad sparkplug wont spark- quite common no matter what they look like externally
greenygreen
yes it has two coils. i was told they were new but i dont think new is right word. they have an M stamped on side. any ways i confirmed the plug was good and there was no spark at end of wire
Bosunsmate
can you swap the leads over and coils and retry?
Do the magnets in the flywheel look ok?
greenygreen
idk it all loooks so confusing.. idk where to start. i noticed inside the flywheel was slightly grinding on throttle lever in one place
Bosunsmate
yeah dont change those over.
Is the one on the left burnt on its top arm?
greenygreen
its not near as clean as it looked thru peep hole. got some cleaning to do
Bosunsmate
Rotate the engine slowly
Are those points ok?
not pitted?
greenygreen
it is burnt i think. looks kinda funny. maybe where it was grinding.. throttle wouldnt stay up by itself
cajuncook1
Hopefully will give you a visual and help you some.
Evinrude Gale and Johnson ignition video 1
Evinrude Gale and Johnson ignition video part 1 of 7 - YouTube
Evinrude Gale and Johnson ignition video 2
Evinrude Gale and Johnson ignition video part 2 of 7 - YouTube
Evinrude Gale and Johnson ignition video 3
Evinrude Gale and Johnson ignition video part 3 of 7 - YouTube
Evinrude Gale and Johnson ignition video 4
Evinrude Gale and Johnson ignition video part 4 of 7 - YouTube
Evinrude Gale and Johnson ignition video 5
Evinrude Gale and Johnson ignition video part 5 of 7 - YouTube
Evinrude Gale and Johnson ignition video 6
Evinrude Gale and Johnson ignition video part 6 of 7 - YouTube
Evinrude Gale and Johnson ignition video 7
Evinrude Gale and Johnson ignition video part 7 of 7 - YouTube
Sorry the camera and video edit software was not all that great. It is very hard to see the spark when I am checking with the spark checker, but in the end I get both set of spark plugs to fire even though you may not be see them. Anyway, I think you will get a good idea how to work on OMC ignition from 1950 to 1973. I know the videos are a little long, so I had to break each segment into 10 min. I am not that good a videoing or editing.
Cheers, hope y'all have fun working on old outboards!!!
Bosunsmate
Can you get a photo of it?
Something gone on there- certainly isnt new!
greenygreen
i think they look ok. just a little loose junk around
greenygreen
here is a little closer
Bosunsmate
Doesnt look too bad, but im not sure, someone else might know.
Is that the coil to the bad cylinder?
greenygreen
im not sure. maybe cajuncooks video links is gonna help me help myself. im gonna check em out in full and see if i can figure out where to stick this ohm meter lol..
