OBJ
Thread starter- Joined
- Dec 27, 2002
- 10,161
Rebuilt the cylinders on my 84' 50hp Johnny. This is the unit with the lift bracket bolted to the swivel bracket and has the three wire pump.<br /><br />While I had the unit on the bench, I filled an bled off the system until reservoir level was even with the fill hole. Reinstalled unit back on engine.<br /><br />Ran engine up and down a couple times and all seemed well. Left the engine tilted all the up. Came back a short time later and noticed the engine had lowered. In the water, when trimed out, throttleing up will push the engine back in against the stop.<br /><br />This did not bode well with my ego so I took the unit back off. Back on the bench, I noticed that when the cylinders are in the full extended postition, I can push down on the trim cylinder almost all the way....never noticed this before.<br /><br />Question is, should this happen or is this natural since this is the trim cylinder or did I (perish the thought) screw up? Maybe didn't get a good bleed on the unit?<br /><br />Thanks for any help<br /><br />Jim
