Benny1963
Thread starter- Joined
- Sep 17, 2006
- 1,476
well ive had ongoing thread about tick in motor pulled flywheel no apparent
probs havent pulled intake . has 6 030 pistons and the bores look good ,
but no way to tell without tearing down would like to replace bad bearing or whatever and replace gaskets and reassemble 1981 evin 150 crossflow.
but parts are rediculus 27$ ahole for rings and 15 dollars for wrist pin bearings . if i tear down and damage is bad then i will spend 2000 to build on other hand used 150 is 1500 to 4000 and you dont know what you have because a simple compression check is not enough anyone with pros and cons on this please chime in because i dont have the money to buy new motor in near future but i could do rebuild over time .
thanks bennyb
thanks bennyb
