Re: to buy? 98 seadoo 718cc opinion
It seems a little high to me unless it is in near new condition inside and out. Especially if there is no trailer included. A used single trailer will run you $250 or so.
Also, do the guages work on it?
texasvet
hey so i went down and bought it. put the jetski in my van..fit nicely
got it for $1800 with all the parts. here is the details:
I have a 1996 Seadoo SPX with a 717 engine that has been fully rebuilt with 0 hours.
THE PWC COMES WITH FULL PAPERS. Everything has been redone inside the PWC and the outside
is in amazing condition. It is one of the cleanest SPX's that I have seen. The 717 engine has
been rebuilt with an Adrian Bernard Crank and connecting rods, WSM pistons, bored jugs and all
american bearings. This motor was built with the best parts for a bulletproof reliable performance.
All of the lines have been replaced, carbs rebuilt and matched, R&D trim tabs, brand new battery and
the VTS motor has been rebuilt. There are only a few things that need to be finished up and would make
a great winter project. All of the parts are included!
Needs To Be Completed:
-Drive Shaft Greased (cover put on)
-Plastic Intake Assembly Installed
-Jet Pump Nozzle Painted and Installed
-Install Numbers on Hull
-Add Oil and Gas
-new decals for hull numbers (any ideas would be appreciated)
I should mention this hasn't been firied so no oil, gas in it at all...completely clean.
we did a compression and one reading was just a tad lower 150psi and the other one a little over 150psi. i will probably do another test to really get the correct reading. question: should you have both plugs out to do the compression reading? he said its better because you can get a inaccurate/higher reading if one plug is on.
Also i have noticed that the choke is not hooked up so i gotta find out about that.
i plugged the batter in and the hour guage showed the red lights...no digits written however so not sure if this is how it is or we got a problem there?
how do i check if the guages work?
sry i have alot of newb questions...really dont know anything about these machines. im looking for the manual too so far no luck. here are pic.
