To foam or not to foam... that is the Question
notsunkyet
Ok guys its been awhile since ive been on alot of other projects got the better of me over the winter! So its about time to fiinsh the Bayliner Capri redo.... when i was last on here i replaced the transom, floors and stingers... i DID NOT refoam. My question is this... i dont see how the foam will aide in bouyancy.. its internal, it does nothing to raise the displacement of the surface area of the boat nor does it help after you load it down. If it gets wet it adds alot of unwanted weight and then theres the rot that will ensue... So am i wrong in this mode of thought? Is my logic flawed? OR is it simply there to dampen hull noise ?Please all chime in and let me know... thanks Notsunkyet Kevin!
erikpn
Re: To foam or not to foam... that is the Question
It's there for support, and to provide back up flotation if the boat is swamped to keep it from sinking to the bottom. If the foam is dry enough to provide buoyancy, it will keep the boat on the surface of the water. Used closed cell foam and it will stay dry.
notsunkyet
Ok so where do i locate the closed cell foam stuff and without taking aloan out for it?
erikpn
US composites has some.. 244 for 40 cubic feet. How big is the boat?
notsunkyet
its a 17 foot capri bayliner it had foam in the front and down the sides under the seats
Smokepole27
Is that the liquid foam? A buddy used it to do all of his boats! Floor is solid as a rock not heavy and more support on the hull. Make sure to drill plenty of holes in your floor for when you pour it in their it has somewhere to go or else itll pick up all your new plywood you put down.
