To gap or not to gap
flpocketchange
I?m, replacing the floor in a 22 foot Aqua Sport open fisherman using ? marine plywood and fiberglass matt/resin. Simple question..... Should I gap the plywood at the seams to allow for expansion? All surfaces will be sealed so I assume that there will be no expansion but I?d rather be safe than sorry by asking the pros.
Mark42
Re: To gap or not to gap
I'd say not to leave expansion gaps. Never saw a small craft with them, and it could be a place for water to get in.
danond
No gaps. There's little to no expansion. If there were, fiberglass boats would be cracked all over.
Robert D
I hate to contradict others, but I'll throw my 2 cents in :) I wouldn't leave a gap on the edges to the hull, but I always leve about a 1/8th inch gap between sheets of 3/4" ply. Why? Not for expansion, but to allow sufficient epoxy(Mixed with milled fibers & a bit of cabosil) to fully penetrate the joint. If they are butted together, you can sitll get some epoxy between the sheets as you assemble, but I feel more comfortable sealing this area after the sheet is down. (Always seal the ends before installing, though, with some resin soaked in.) I liberally use the epoxy mixture, wait for it to cure a day or two depending on temperature, then sand it smooth...I use this same mix where the plywood meets the hull, for a fillet. Then tab the plywood sole up the hull about 3 inches, followed by a layer going up 6 inches. Sand everything smooth again with an orbital sander, then glass over the entire sole and up the hull about 8 inches. All that's left is to decide is if you want paint, carpet, or the bedliner some are using. Just make sure you cover it with something, as the UV light will break down the epoxy I hear. Most of this is a personal choice. In reality. the butted together ends with a thin epoxy, and glassed over are probably just fine. I just like to do it once, with overkill, and know I'll never have to do it again. The negative side to this: If I or anyone else has to tear into a boat I rebuilt, it will be 3 times the work getting through the extra layers of glass, etc. I figure by the time that becomes necessary, hopefully I'll either be long gone or 130 years old:)
