I found a way.
A length of 3/8"ID clear plastic tubing slipped over each end of the OMC-3300 Teleflex cables I use makes a nice snug fit. I connected one end to an A/C service vacuum pump, dipped the other end in WD-40 and let the vacuum pull it through. I exercised the cable, did WD-40 again, then drew a thin anti-corrosion lube through it.
Worked great.
Tom
Worked great.
Tom
