glenn property of pam
Thread starter- Joined
- Feb 17, 2012
- 2,906
i have a 91 stratos 1135 max weight with 4 people on board. running with only 2 people using a 84 evinrude 70hp at 35.5 mph on gps my engine is maxing out at 5000 rpm. the prop is a 13-1/4 17p stainless 3 blade is real good condition the boat has trim and tilt and a oversized tail fin on the cavation plate. my only complaint is the engine takes a little while to wind up and im wondering if i should be on a 12-3/4 prop. the original prop on the boat was a 12-3/4 21p aluminum and that acted just about the same as this one (never got the readings before i changed it) engine max rpm is 5500. boat does plane out nicely and the trim does keep the boat stable on take off just wondering if that extra 500 rpm top range will free the little motor off a little at lower rpm
