Re: To VRO or Not
Thanks for the opinions guys but a few more comments and questions and I'll let it go!<br /><br />I know that the "Low Oil" warning works, because I have been low enough once, where the horn did sound at the 20 second interval. Are there any other warning that should sound that would protect the motor before destruction? I believe from looking at the Clymer manual that it will sound every 2 seconds if the pump is not getting oil at all(AKA Kinked Line, ECT), but will the motor be dead by then or if I shut it off right away, can I save it? The manual also says that I can still mix a 50:1 with this VRO system if I want. Is the VRO smart enough to determine the oil ratio if I pre-mix along with having the VRO hooked up? I find that hard to beleive! Seems like it would be running very rich on the oil side if I did that! I know when I first got the motor back, they had me run it for the first 10 HRS with 50:1 in the gas tank, along with the VRO running, too. That was to be sure that the VRO was working properly and I really did'nt notice an over abundance of smoke or anything during that break-in time, although I was putting oil in the tank and the VRo also. Seems like that would be a waste of oil to do both! I am mainly concerned that the 2 sec. warning will save my engine as it supposed to do! If not, goodbye VRO!! Once again, Thanks and any other thoughts are appreciated! Rick (PS- How do I make sure the 2 sec warning is working correctly?)
