hi-tech redneck
- Joined
- Nov 22, 2002
- 4
Re: To weld or not to weld...
Hello all ,<br />After looking at your pictures the boat can be welded with no problem you may want to call around to some local machine shops or sheet metal shops they do the weilding you require.<br />I would not use polyurethane it is hydrophillic it draws in moister and it will probally cause some major anodizing over time.<br />If you lived down my way i would weld it for you for a couple hundred dollars weld only, i don't do carpet
