garbageguy
- Joined
- May 8, 2012
- 1,598
1998 Wellcraft 240 SE with repower 5.7 liter GM normally aspirated. VP Cobra outdrive, I think Merc electronics on the engine. Got it used, replaced 5.7 with long block 2-3 years ago (frankenmotor?). It runs very well, but the keyed ignition switch plastic broke. I am able to start/run by pushing the plastic ignition switch together with key and turn it, while working throttle in neutral. But I really should replace the ignition switch. Thinking about a 3 way toggle (off, run, start) with a spring on the start position - instead of key. Any input, suggestions, experience with this appreciated.
Closest pic to ignition switch I could find. attached
