Tohatsu 2 stroke 120A2 upgradable to 140HP?
DoubleWeber
Ive been told that this motor could be a 140hp just by some easy tinkering.
Is that correct?
This is the motor
Sea Rider
Re: Tohatsu 2 stroke 120A2 upgradable to 140HP?
Both engines shares same 1778 CC block, 120 has 17.5 timing advance and 140 has 20.0 timing advance. If carbs are directly rod linked to timing advance plate as in other models, much faster & easier to adjust. Check what's stopping the carb to be fully opened, that will be the timing & carb restriction.
Happy Boating
DoubleWeber
Thank you for replying :)
I will check it out.
