phillnjack2
Ensign
Thread starter- Joined
- Apr 30, 2011
- 918
Hello everyone
A friend of mine has a tohatsu 25hp that is in good condition with good compression
model is M25A2
We had a problem in the coil and it completely died, so we got another secondhand coil due to no new coil availabilty.
this worked for a few weeks then that too packed up due to old age etc.
the original coil was a one piece coil with the 2 sparg plug leads comming out of the single unit.
There is just 1 wire that goes to the coil from the cdi pack.
so we had nothing , but then we decide to fit 2 single coils we had lying around that we know are good.
We rigged them up,using the 1 single wire to the first coil,and a jumper lead from that wire to the other coil.
Now the engine runs fine, gives a good idle, and seems to be making top speed no problem.
We have since heard about double firing !!!!!!!!!!!!!!!!
As we have been told that using 2 coils running from the one lead will be giving a double spark,
as in 1 spark before btdc ,as normal, and another spark when piston is travelling down.
This would happen as the 2 coils are sparking at the very same time !!!!!!!
is this going to cause engine destruction in any way ?
is there another method of using the 2 coils,or do we need to find a similar double acting coil that
uses just the one wire from powerpack like the original.
please help before we do any damage to this good old engine
phill
model is M25A2
phill
