Tohatsu 25hp - Need information regarding removal of needle bearing for input shaft
TOHATSU GURU
Re: Tohatsu 25hp - Need information regarding removal of needle bearing for input sh
What does that service manual that you have show?
pvanv
Agreed. Get the proper Factory service manual. The Factory way is to pull the bearing.
Sea Rider
For ball bearing located at extremes will need a bearing puller, for needle bearing removal from crank shaft will need to tear it into pieces at a machine shop or on your own if knowing how to do it, will need to press back all crank shaft parts to factory specs once all needle bearings are replaced with new ones.-
Happy Boating
