bansil
Thread starter- Joined
- Oct 27, 2016
- 115
Hello,
Tag 3.5 A2
I picked up a 13ft aluminum boat and it came with this mounted to the back, I took it off to fix the transom and decided to look at it today
No numbers on engine anywhere, id with decals and the Tohatsu website
1)Good bright spark
2)Plug looked good
3)Cylinder looking through plug hole looked good
4)good compression (no gage just felt good with throttle closed and plug in)
It turns over so my reason for the thread
The fuel line is a "stepped" rubber fuel line with a small and big end (which is cracked and not long enough or pliable to cut back)
it needs to be replaced, where to buy?
The small end goes to the vacuum fuel pump?
and gas tank on back side
What fits here, beside the line going to carb?
Also this is not connected to anything and it looks like it has been cut
I haven't had luck finding pictures online
Tag 3.5 A2
1)Good bright spark
2)Plug looked good
