Re: Tohatsu 3.5hp 2-stroke V.S the Tohatsu 4hp 4-stroke?
Some models of the 3.5 have only forward (always in gear), some have neutral and forward. None have reverse.<br /><br />The 4hp has F-N-and Reverse, and is a more "sustancial" motor, more sturdy, etc.<br /><br />More important, is the shaft length needed. Both only come in 15" shaft length according to my brochure. <br /><br />Edit: My mistake, they are available in 20 shaft also. Just hard to find the info in my brochure.<br /><br /><br />Double check that a 15" shaft will reach below the bottom of the hull, or all you will do is suck air and splacs water with your prop.
