pvanv
- Joined
- Apr 20, 2008
- 6,571
Re: Tohatsu 40HP 40 TLDI Wont Run Below 2000 RPM and Requires Half Throttle To Start
"I have been using Part# 003-21050-1 service manual for my 40B engine."
You have the manual for the MD40A, not the B. That's a problem, as there are significant differences between the A and B motors.
"Please take a look at the attached table. At a tach reading of 5000, I have only the rightmost LED lit up. Does this suggest the CPS is at fault? OR -- is this an impossible combination? I don't understand the logic of the table and need help. For a faulty CPS, must the tach be at 5000 (it is), the first LED unlit (it is), the second LED lit (it isn't) and the third LED lit (it is)?? OR does the table suggest that for a bad CPS the tach must be at 5000, and either of the two right LED's can be lit to flag this??"
The rightmost LED means there ONCE WAS a failure. If the middle LED were on, it would indicate that there is CURRENTLY a failure. Your indicators and symptoms would lead one to feel that you have an intermittent issue, possibly a marginal wiring connection.
You can test the TPS sensors, and you can test the CPS. I would also re-check and VERIFY all wiring, including crimp connections.
