I picked up a pontoon with a 70 on it and finally got out to the lake with it today. I should mention that the person I bought it from had let it sit up for a couple of years.
Starts and idles with throttle lever fine, and a bit after fully closing the idle lever. When in gear under a load it runs up to 2500 or 3000 rpm and that's all. Very sluggish and then starts to be more sluggish. Took off engine cover and noticed when idling and revving a little manually a small back fire on the bottom cylinder on the side of the motor with all the linkage. Back behind the carbs in the middle of the engine. Almost like a backfire on the side of the motor when idling down or on the way down to just idle.
Any thoughts or ideas.
Thanks
Thanks
