tohatsu 8hp prop
dstark
My 2009 tohatsu 8hp came with a 8.5"-8" prop, can anyone tell me what I would gain or loose by putting a 9" pitch on it. Thanks
steelespike
Re: tohatsu 8hp prop
If you read the stickies at the top of the page and the helps on the prop store page
it will help you understand prop selection.
going to a 9 would reduce the power might increase speed if the motor can still turn up to its designed rpm.
Your results would depend on what the motor is on and your typical load.
If your hoping to improve your overall performance weight reduction and placement is critical.If your having trouble planing; a tiller extension so you can sit in the middle seat will help and probably improve max speed as well.
