buccaneer_35
- Joined
- Nov 5, 2010
- 10
Hello,
Before I resort to the Guru's third option, I wanted to try this forum. Having read dozens of posts on the forum here, it seems as if I had the classic dirty carb (only idle on high). I pulled it apart two nights ago (and also repalced the pull-cord), cleaned the carb using Berrymans, and put back together. It started on the second or third pull, but I didn't have a water bucket, so I shut it down after 30 seconds or so. I go back to my shop today, this time with a bucket, and I can't start the engine. I also took the time, two nights ago, to change the engine oil and gear oil. This morning I put the Tohatsu 9.8 back on the boat, hooked up all the wiring, but still it won't start. My instincts tell me there is an electrical issue.
I know that it could be many problems, but I'm wondering if, to those of you with many years of experience, you are thinking, 'Oh, it's probably XYZ'. Is there a common mistake I might have made in putting the carb back together?
Thanks for you help,
phillp
phillp
