Tohatsu 9.8hp 20 hours service....
krell101
Besides changing oil and fuel filter what should be done for service?
I am planning it to be service at a TOHATSU dealer but if it is just something
simple like oil change I can do it myself
Thanks in advance!
TOHATSU GURU
Re: Tohatsu 9.8hp 20 hours service....
Theory says to check the valve tolerances too. Theory is a waste of time 499 out of 500 times. No need to change the fuel filter at all. Just change the gear oil and engine oil. DO NOT USE SYNTHETIC OIL.
krell101
Thanks GURU I will just change the engine oil and gear oil. I can do that myself and save money =)
krell101
Tohatsu guru what brand would you suggest for the engine oil and gear oil?
Do I have to buy a pump so I can drained all the oil out?
Thanks
TOHATSU GURU
Synthetic oils do their job too well when they reduce friction...It brings down the operating temp and that leads to fuel dilution of the oil which leads to wear on the engine.
NJS0930
Thanks, TG, for the explanation re: synthetic oils.
